that warning appeared at my behest, prior there was NO indication at all, anywhere
Thank you for that, then. I actually went back and checked the changelog on the Wiki front page after posting because bad memories of some significant issues with the documentation that existed a couple years ago when I built my first XT-CF suddenly came flooding back. (There was this period where it was actually really confusing to find the Download page at all if you came in via the front door.) So... yeah, the docs have certainly had their gaps in the past. At least it's there now.
That said:
You say "insisting" on not reading the docs implying people are being belligerent, when in reality the most common MO throughout the history of technology has been "try first, read later."
I know it's been everyone's gosh-given right as an American to just dump the newest hyper-sophisticated miracle of modern science out of a box, plug it in, and have it "just go" since the 1950's, and based on such it
would be a reasonable expectation for someone, say, buying a complete XTIDE card to assume the BIOS chip on it was set up to at least accommodate the default jumper settings so it's "plug and play". But the BIOS
itself isn't a "consumer" item, it's "system integration"-level code that typically *will* require customization for whatever hardware it's intended to go with, and making the wrong choices can in a significant number of edge cases create crash-severity conditions. Having an unconfigured image do "nothing" is the safer option compared to having it try to do
wrong thing.
(If the code had more capability to at runtime autodetect hardware this would be less of a problem, but as it is it requires re-flashing the ROM if you change port hardware addresses, let alone what hardware scheme you're using.)
If someone wanted to take on the job of curating pre-configured ROMs for various common configurations maybe that wouldn't be the worst idea ever. I haven't used the AT build, only the XT ones, and on the XT side of the fence 16-bit "full" XTIDE and 8-bit XT-CF-lite hardware seem to be about roughly equally common and there are significant type variants of both. Therefore the chances that a "generic" binary will be correct one seem pretty low. Maybe there
is a "generic" AT config that covers 95% of use cases with no further config?
