Nothing changes! D3 is always different from others!! ((Pin 13 is D3.
Turn the timebase down two or three more steps and look again at all of D0-D7, with the timebase kept at the same (lower) setting for all of them.
Actually I use one of these... https://www.ebay.it/itm/183686874231 which gives 16 channels. It's not easy to configure but works pretty well once it is working. Shows traces in the digital domain.how do you use this?
This not possible! Because with the slower timebase speed (0,5s) i can't see any waveform I am desperate!!!!Could you please show us D0 and D3, both at the slower timebase speed, so that we can see them too.
Nivag, I think the problem with analysers is that the inputs only see logic '1' above a certain threshold and logic '0' below a certain threshold, they don't display the true state of a signal which on a faulty machine could be at half-levels or intermediate levels.
Thanks! I checked both probes and are ok!Desperado: Dave mentioned this before;
On your recorded waveforms there is peak or overshoot on the waveform's rising edge and when it falls an undershoot, appearing to peak below zero volts.
This is because the scope probe assembly, versus the scope's input capacitance, is not correct and there is a peak in the high frequency response. So those voltage overshoots you are seeing are not really there. Sometimes though, the frequency response can be altered with a long length of wire in series with the probe tip or probe earth too.
On the probe's plug, there will normally be a small hole to access a trimmer capacitor (small variable capacitor).
When a scope probe is married to the scope for the first time, the scope probe is normally clipped onto a calibrator test point (often on the scope's front panel sometimes on the rear) that has a fast rise and fast fall 1kHz square wave. And the small capacitors on the probe's connector are adjusted to make the shape of the square wave as rectangular as possible just after the rising and falling edges of the wave and eliminate those peaks. (see attached image)
If there is no calibration square wave on your scope you can find, you could adjust the probe's trimmer capacitor using one of the waves from the pet, it won't be 100% accurate but it will be a lot better than what you have now.
Ok this is 20ms:OK, so that is still a little bit slow. Try again, d0 and D3 this time at 20mS. This is what Dave meant, trial and error, you have to look at the signals at various time settings to get a 'feel' for whether the signals look right. This is something you will eventually get used to.
In those captures we are starting to see that there is not actually much difference overall between D0 and D3, they are about the same height, they are active and inactive for about the same length of time. Look at D0 and D3 once more, this time at about 2mS.
Yes, i have same waveform in every pin!So again, D0 and D3 are looking quite similar and we can see some very square looking edges in there. Staying at 2mS, now look at D1, D2, D4, D5, D6, D7 - no need to post videos of them, but just look to see if they also look about the same as D0 and D3 and report back.
