daver2
10k Member
If you are going to read the manuals (), OS/2 should also be able to tell you what resolution the video card is running at...
You can then compare this to the specifications for the monitor you are displaying it on. The native screen resolution needs to be the same as (or higher than) the resolution you are trying to display.
