It sounds like he was getting private confirmations of bids or something. Oh well.
Okay lets move on from that stressful tenure and go back to trying to get my machine to run using loaned parts and collected information.
MITA provided me with the I/O cables last year to duplicate and build a pinout. The blue plastic cable hoods were also a problem as they are basically NLA however another four-phase engineer offered to look into it and sent me several complete sets of 3D printed replacements which I'm VERY happy about. Meanwhile Sellam during VCF West let me look at his system to investigate a few things and get the information needed to build the missing cable that runs from TB4 on the power supply to JP3 on I/O board 2.
What was interesting with sellam's machine is the sharpie marks on all of the power supply cabling is factory. We both have it. What also I find interesting is that while MITA and Sellam have the cable up to I/O 2 mine was missing when I got it and that's why I suspected mine was missing because mine instead had three Hi/Lo switches on the back of the machine, however Sellam's did not have those switches, so now I'm wondering if this was a configuration change or option and you are not supposed to have both. There's no information on this.
(Note the wire color coding. They are all identical to Four-Phase spec but they are all flipped between terminals)
Four other things however we got at VCF West and Sellam.
-Sellam let me inspect and confirm that the Four-Phase 8503 tape drive is a Wangco 8B37 tape drive (on bitsavers the brochure calls it the Model 8)
(I am still by the way seeking a Wangco drive. It seems all of their families of drives at this time used the same 3-cable formatter interface which is not Pertec or Kennedy compatible)
-While at VCF West I played Courier for a third party. A Zero Halliburton case containing the test jig for the IV/90 processor appeared in Cupertino. I picked it up, brought it to Canada so it can be used to try and see if there is ANY life in my IV/90 after all of this insanity to make the main IV/70 cabinet is dealt with and it has been extensively photographed and uploaded to Bitsavers. Have fun!
This jig
technically does not belong to me. It's on loan from its current owner who is letting me hold it until my work on this machine is done. Part of the deal was I had to take the above photo documenting of the unit.
It plugs into the memory board and the two boards that make up the CPU. It lacks a front panel to toggle anything into the processor from the jig but gives you an output display presumably in octal and three rotary selector wheels.
The controls for P and BP are total unknowns so far. There's no documentation, not surprisingly.
-I picked up one more RAM-9 chip. It's untested but like Thanos searching for the Infinity Stones, that is one last missing ram chip dropped into my otherwise complete set of ram boards. One more remains.
Here's a photo of that chip in front of Apple's DeAnza 3 office, formerly Four-Phase's second building across the street from their headquarters (now Infinite Loop)
-Someone at VCF West was selling rail kits for Model 30 Diablo drives, so now my drives can be racked! The same person was also selling a model 31 drive, albeit because of missing cover panels and a broken upper head, strictly for parts. It still has lots of good parts otherwise and a very clean HEPA cartridge.
(I still have made ZERO progress finding 8-sector packs. We may never actually end up using these in favor of the ongoing Diablo 30 emulator project.)
Lastly, on my way home from the show, RE-PC had a Documation M200 come in. I already have an M1000 but it's massive and I'm at the mercy of
when the rollers fail and MITA supposedly still has decks of Four-Phase engineering cards. The M200 is a smaller machine so it might be nice to purchase a second reader so I can integrate Kyle Owen's into the machine.
However they didn't want to sell it until BossMan got the final say on price, which I wasn't going to hang around the shop all day for him to wander by, so I left my number and they said they would call when he had a number.....two weeks ago. [rolls eyes heavily]
Okay, so back to the machine.
The gerbers for the protoboard and the riser card came back so we now have the ability to prototype new boards for the standard Four-Phase backplane. The riser also has four LED's on them so you can also monitor the voltage rails.
Aaaaaaaaand we're back to the power supply again. :I
We had issues with this before and it came back on Saturday when I was smoke testing before putting the machine together and seeing if we had life which was extremely disappointing, then I got pulled away until this evening because of a work call. Sometimes the +5 comes up. More often than not you get a chirp, 0.66v, awful noises and the squawk you would get out of a crowbar circuit after the supply had been shut off and it was resetting, except this is a linear supply so that means something else is unhappy and occasionally "fixing" itself. Well the rail only has 180 ohms on it with just the empty backplane and front panel and it does not seem to be a loading issue because if we completely de-wire the system and load the +5 it still doesn't want to behave, so we will again have to remove the power supply and nail down what is going on before we can safely power the machine up.
We do not have any schematics for the power supply.
