voidstar78
Thank you, yes Initial is right ! I was pretty shocked to see this difference just by swapping between the two available Common and Language ROS cards. I'd be sad to get a 5110, but couldn't do anything with it without a functional disk drive (i.e. by not being able to by pass this).
I tried by-passing this in other ways - CMD-ATTN, CMD-HOLD, CMD-+, etc, no luck.
I suppose another possibility is that this other Common and Language ROS card actually is faulty. i.e. the BRANCH past this particular test happens to be corrupted? So I was curious if others had this experience with a 5110 Type 2 of not being able to by-pass the AUX IPL 013 D80 error.
(also FWIW, the two Type-2 5110 I have both only have 8 "tin cans" on their Executive ROS; contrast to the Type-1 5110 that I have which has 9 "tin cans" on its Executive ROS -- that extra tincan might be added tape-deck support, not sure yet -- that said, the "type 1" executive ROS also works in my "type 2" 5110 {and can by pass this 013 D80 error, and they're both from mid-1979}).
