Jackson
Stop urging me to remind myself that I haven't fixed the main problem with my color monitor that prevents it from functioning.... :mad1:
This wouldn't get yellow correct, however (see previous discussion on how the monitors intentionally display yellow as dark brown).
I would buffer those analog RGB signals through a THS series amp from TI. DC coupled on both ends. You would need to get +5 somehow to power it. If it's not available on the digital RGB output connector throw a 7805 on there and grab the +15
Not to worry you, but on my CRT319 it is indeed brown:
View attachment 60514View attachment 60515View attachment 60516
Not that you can do anything about it, but I wanted to let the record show that the CRT319 shows brown, which is also what I remember growing up with. I can try to test with a Xerox 6060 monitor and I think I have a CRT318h if it's really needed, but if possible, #6 is supposed to be brown.
Hello, this just looks great! Thanks for the effort. I will take definitevly some of the final version adapters.
You may have again a look into the german forum, the guy there uses a TTL gate to amplify the signal output of the video card (there it is a Hercules card). Maybe you can use a single 74LS244 (bipolar TTL) or better 74HCT244 (unipolar CMOS).
Vincenzo--a small "nit" It's a DE-9 ("E" sized connector with 9 pins) A DB-9 would be a very different animal.
Hello Chuck(G).
Do you believe me if I tell you that in Italy the serial connector with 9 pins is called DB9 and the parallel port (Centronics) connector with 25 pins is called DB25?
So, actually, if I tell it in the Italian way I should write as I did. A DB25 to DB9 adaptor to plug the output of the M24 indigenous board to the MCE2VGA from Luis Antoniosi.
In the US it should be DE25 to DE9 adaptor, then.
But I am happy anyway we both understand, despite the different language conventions, the meaning of what I wrote.
