fdiskitup
I can write to memory !
For example
>M 7000/
When you type the / it gives you the current contents of memory location 7000, then you type in your value press space and you get the value at the next address, keep using space to go through the addresses or enter to stop.
>M 7000/FF01 FF02 FF03 <enter>
A dump shows the values are stored in 7000, 7001, 7002 etc.
(This means my ram board is working, at least at 7000.)
In a burst of over confidence I then wrote a program into 7000 to load A with 2 and add 2 then store the accumulated value in 7010….
Just typing
>G 7000
Crashes the system, so I think I need to set up the G command with an entry and exit ?
Not far from a “hello world “ program now…
For example
>M 7000/
Just typing
>G 7000
