It's not possibile!! i have end scale now ( 2 us)You need to slow down your timebase as we measure successive pins down the counter chain (i.e. higher-numbered SAn lines).
i am desperate, it's too difficult for me found correct inuput pinsYes, spot on!
Now do, the rest...
I am on a webinar at the moment. If you can't work out what the remaining input pins are I will help out in an hour or so.
I think that F5 pin 14 is bad! I can't see a correct signal also if i try to slow down timebase and turn on triggerYou need to slow the timebase down again for F5 pin 14...
