Hi All;
I asked Tradde what His Switch settings were on the M7856 Switch 4.. Since I had them all OFF..
He sent me the Switch settings He had, which were different than what I had implemented..
The only one that I needed to change from His settings was He had two Stop bits and I tried that and it didn't Work.. But, when I changed it Back to 1 Stop Bit.. And them tried it..
IT WORKED I HAVE SUCCESSFULLY BOOTED FROM THE TU58 EMULATOR !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
No One Told me, Nor said anything about having switch 4 position 1 and 7 ON !!!!
And that is what made the Difference..
177777 177777 057774 177777
@DD)
@DD0
177777 177777 177777 177777
@DD0
MEMORY MANAGEMENT UNIT NOT FOUND
BOOTING UP XXDP-SM SMALL MONITOR
XXDP-SM SMALL MONITOR - XXDP V2.6
REVISION: E0
BOOTED FROM DD0
16KW OF MEMORY
UNIBUS SYSTEM
RESTART ADDRESS: 072010
TYPE "H" FOR HELP
!!!!!!!!!!!!!!!!!! (And Here is the Rest of the Story) !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
.H
HELP for XXDP V2 HELP.TXT Rev: 6.0
________________________________________________________________________________
LIST>
-- The commands outlined here are for XXDP V2 only!
LP: = line printer
TT: = Console terminal
SM: = Small monitor
XM: = Extended monitor
HELP is available on the following topics:
BOOT BOOTSM CHAIN CLEAR COPY DATE DEFSM
DEFXM DELETE DIRECTORY ENABLE HELP INFONBOOT INITIALIZE
LOAD NOTES PRINT RENAME RUN SET START
SMALLMON SWITCHES TYPE UPDAT V2.4 VERSION
INFONBOOT>
-- XXDP V2 can boot two monitors (XXDPSM or XXDPXM). The "SM" or Small
monitor is for systems that are 28k or smaller in size, the "XM" or
Extended monitor is for systems larger than 28k. The "SM" monitor
works like the monitor of XXDP+ V1 and will run all programs written
for V1. The "XM" monitor offers the new features advertised in XXDP V2.
By default you will boot up the "XM" monitor provided the system has
enough memory and memory management capability.
Start-up file BOOT.CCC
At boot time, a start-up file BOOT.CCC will be executed as a chain file.
If this file does not exist, there will be no warning message, boot will
continue and by default the "XM" monitor will be booted up. If the file
exists, it must contain one of the two commands listed below. Only one
of the two commands may be used at a time and it should be on the first
line of the file with no leading spaces. If the file does not contain one
of the two commands it will boot up the "XM" monitor. Note, if the system
does not have more than 28K worth of memory or memory management capability
the "SM" monitor will be booted up.
SM - Boots the "SM" monitor.
QUIET - Boots "XM" monitor in UFD mode. (SYSTEM.CCC must exist)
SMALLMON>
SMALL MONITOR (XXDPSM)
The following are legal commands : (format of each command is shown)
C - run a batch job (chain)
C filename.CCC[/switches]
D - list directory of load medium
D[/L][/F] "/L" switch = on a LP:
"/F" switch = in a short form.
DAte - inspect or set the current system date.
(For more information see "HELP DATE")
E - enable alternative drive for system device
E n where n is the new drive number
H - type help information about XXDP V2
H[/L] "/L" = print on a LP:
L - load a program
L filename[.ext]
Example:
.L DIAG (load DIAG.BI?)
.L ZDJCA2.NEW (load ZDJCA2.NEW)
R - run a program
R filename[.ext] [addr]
S - start a program
S [addr]
VT - toggles the console terminal type between video and hard copy
(The default terminal type is hard copy)
EXTENDED_MON>
EXTENDED MONITOR (XXDPXM)
The following are legal commands : (format for each command is shown)
(Letters shown in upper case are required to make a command unique)
BOOT>
Boot - directs monitor to boot another XXDP device
Boot dev:
BOOTSM>
BOOTSm - directs monitor to boot up the small monitor.
BOOTSM
COPY>
COpy - transfer files and maintenance operations
COpy[/BOOT ] input-filespec output-filespec
[/FILES ]
[/DEVICE ]
[/DELETE ]
Examples:
.COPY A.BIN DY0: (Copy A.BIN from system device to DY0
.COPY/BOOT DM0: DM1: (Copy monitor from DM0: to DM1
.COPY/FILES DL0: DL1: (Copy all files from DL0: to DL1
.COPY/DEVICE DY0: DY1: (Copy device image from DY0: to DY1
CHAIN>
Chain - execute a batch, or chain file. The file must be a .CCC
CHAIN filespec[/switches]
CLEAR>
CLear - Clears the SM and XM flags. When these flags are cleared
they allow the monitor to check bit 12 of location 52
before running any program. If bit 12 is set the program
will be run under the extended monitor. If bit 12 is not
set then the program will be run under the small monitor.
Note :- On boot up (by default) these flags are cleared
and can be set by issuing the DEFSM or DEFXM command only.
DATE>
DATE - inspect or to set the current system date
DATE dd-mmm-yy (Default dates are 01-JAN-84 for SM)
( 01-JAN-87 for XM)
where
dd = day (a decimal number from 1 to 31)
mmm = month, first three characters
yy = year (a decimal number from 83 to 99)
Example (setting date):
.DATE 18-MAY-83
Example (obtaining date):
.DATE
18-MAY-83
DELETE>
DElete - deletes the file(s) that are specified.
DElete[/NOREWIND] filespec
[/NONAMES ]
Example:
.DELETE DU0:ABC.BIN
.DELETE/NONAMES DU0:ABC?.BIN (No file names will print)
.DELETE/NOREWIND MU0:*.TXT (No tape rewind between files)
DIRECTORY>
Directory - list all files on a XXDP device.
DIRECTORY[/PRINTER]
[/FAST]
where
/PRINTER = print on LP:
/FAST = show in short form
ENABLE>
Enable - enable alternative drive for system device
HELP>
Help - types HELP.TXT which contains help on XXDP V2
H[/PRINTER]
Help = Displays topic list
Help ? = Displays topic list
Help * = Displays help on all Topics
Help Topic = Displays help on that Topic
Help To* = Displays help on all topics
starting with the letters "To"
Note : To exit help, simply type in EXit or a carriage return.
INITIALIZE>
INItialize - initialize device directory into XXDP format.
INITIALIZE device: CAUTION: All data on device
is lost!
LOAD>
Load - load a file into memory
LOAD filespec
Example:
.LOAD ZKXCA0.BIC (load DIAG.BI?)
NOTE: This command is used to load programs whose extensions
are (.BIC, .BIN or .SYS) only.
PRINT>
Print - Print contents of files on the specified device on LP:
PRINT[/NOREWIND] filespec
Example:
.PRINT DY0:SYSTEM.CCC
.PRINT/NOREWIND MS1:*.TXT
RENAME>
REname - change the file specification of an existing file
RENAME input-filespec output-filespec
Example:
.RENAME DX1:DIAG.OLD=DX1:DIAG.BIN
RUN>
Run - load and start a program that is stored on system device.
RUN filespec [addr]
Examples:
.RUN UPD2 (load/start UPD2.BIN)
.RUN SAMPLE.XXX (load/start SAMPLE.XXX)
.RUN FXDIAG 204 (load/start FXDIAG.BI? at location 204)
SET>
Set - changes device characteristics and system parameters.
SET [ device ]:condition
[ item ]
where "device" = device whose characteristics are modified.
"item" = system parameter that needs to be modified.
Examples:
.SET TT:SCOPE (RUBOUT will delete characters - XM Default
is SCOPE)
.SET TT:NOSCOPE (RUBOUT will echo deleted characters -
SM Default is NOSCOPE)
.SET TT:QUIET (Prevent system from echoing lines from a
chain file or from diagnostics that are
running from a chain file)
(Default = NOQUIET)
DEFSM>
DEFSm - Sets the SM flag. After issuing this command all programs
will be run under the small monitor until the CLEAR
command is issued. Bit 12 of location 52 will not be
checked at all and by default any program(s) run after
this command is issued will be run under SM.
Note of caution :- If you plan to run only one program
under SM and issue this command make sure you issue the
"CLEAR" command after your program has completed running.
Else by default every program will run under SM regardless
of whether bit 12 was set or not.
DEFXM>
DEFXm - Sets the XM flag. After issuing this command all programs
will be run under the extended monitor until the CLEAR
this command is issued will be run under XM.
under XM and issue this command make sure you issue the
Else by default every program will run under XM regardless
START>
Start - start a file that has been loaded into memory via LOAD
START [addr] A starting address may be entered
TYPE>
Type - prints the contents of a file on the terminal
TYPE[/NOREWIND] filespec
Example:
.TYPE/NOREWIND *.TXT
VERSION>
Version - Prints information about the Extended monitor.
Version
V2.4>
There are some major differences in V2.4 and all of the previously
released versions of XXDP V2. The main difference is the way programs
will be run from now on.
In previous versions, programs were run under the same monitor that
was displayed on boot up. i.e. if you booted the small monitor you
ran all your programs under the small monitor. If you booted the
extended monitor you ran all programs under the extended monitor.
The problem with this was that you would have to reboot the other
monitor if you had a program that ran on one and did not run on
the other.
In V2.4 (and following versions), this problem is solved, programs
will be run after a check is made on bit 12 location 52 (after the
program has been loaded) and if this bit is set the program will be
run under the extended monitor. If this bit is not set, the program
will run under the small monitor. Unlike the previous versions there
will be no need to reboot.
Bit 12 of location 52 should be set by using the "UPDAT" or "PATCH"
utility. If UPDAT is used you might have to change the LOCORE of your
program. Please sure the "CLR" command is issued before loading the
program and changing the locore.
Note : Look at the "DEFSM", "DEFXM" and the "CLEAR" commands in this
help file if you are unable to set bit 12 by using the utilities.
SWITCHES>
Switches - are not applicable to all commands
- these switches are not system defaults
/NONAMES = No file names will be shown
/NOREWIND = prevents tape rewinding between files
UPDAT>
UPDAT program
This program uses the same commands as UPD2. Commands SAVM and SAVE are
no longer supported. The following command has been added to build
bootable media. It will work with tapes or disks.
CREATE DY0: (will create a bootable DY from your system media)
NOTES>
CAUTION : Do NOT use XXDP+ V1 to write to XXDP V2 media.
XXDP V2 may read or write to XXDP+ V1.
NOTE : The monitor only sizes to 124k words.
* For a detailed description of these commands see XXDP/DRS User Manual
.D
ENTRY# FILNAM.EXT DATE LENGTH START VERSION
1 XXDPSM.SYS 1-MAR-89 29 000047 E.0
2 XXDPXM.SYS 1-MAR-89 39 000104 F.0
3 DRSSM .SYS 1-MAR-89 24 000153 G.2
4 DRSXM .SYS 1-MAR-89 48 000203 C.0
5 DATE .SYS 1-MAR-89 2 000263 B.0
6 DB .SYS 1-MAR-89 2 000265 C.0
7 DD .SYS 1-MAR-89 3 000267 D.0
8 DIR .SYS 1-MAR-89 7 000272 D.0
9 DL .SYS 1-MAR-89 4 000301 D.0
10 DM .SYS 1-MAR-89 4 000305 C.0
11 DR .SYS 1-MAR-89 3 000311 C.0
12 DU .SYS 1-MAR-89 4 000314 E.0
13 DUSZ .SYS 1-MAR-89 2 000320 C.0
14 DY .SYS 1-MAR-89 3 000322 D.0
15 LP .SYS 1-MAR-89 1 000325 B.0
16 MM .SYS 1-MAR-89 3 000326 C.0
17 MS .SYS 1-MAR-89 4 000331 C.0
18 MU .SYS 1-MAR-89 4 000335 E.0
19 HELP .TXT 1-MAR-89 29 000341
20 PATCH .BIC 1-MAR-89 31 000376
21 SETUP .BIC 1-MAR-89 27 000435
22 UPDAT .BIC 1-MAR-89 29 000470
23 XTECO .BIC 1-MAR-89 26 000525
THANK YOU, TRADDE and DON and RSX11M and SMP for all of Your Help and Suggestions..
THANK YOU Marty
