PDP-12 #435 at the University of Minnesota Duluth
It would be difficult (very or extremely might be good to add before difficult) to add to an older machine like a PDP-12.
I'm not sure if you know this, @DougIngraham , but my former student Julian is working on a "nonvolatile 24k on a card" flip chip that, with some daughter cards and ribbon cables) plugs into the interface to the external 24k cabinet. So, once that's working, any 8k PDP-12 will be able to easily jump up to the full 32k. He's made one version that worked in some sense but had some showstopping bugs that he's working out.
That sounds like a really interesting project but that is not changing the extended memory system to allow for the 17 bit addressing that is the 128k mentioned in the video or found on the 8/a.
I look forward to hearing how Julian's project turns out.
Actually you could get an EAE on the 8/a. They did this by using the 8/e CPU (KK8E). You replaced the M8615 (KK8A CPU) in slot 1 with the bus terminator card and put the other CPU cards in the bottom slots of the 8/a chassis. One of my 8/a machines was equipped this way.
I'd describe this as an 8/E CPU with EAE in an 8/A chassis. It was done fairly often, though, as a solution to the problem that there's no way to extend the 8/A CPU card to include EAE instructions.
Vince
Yes, of course. The connection was "adding memory to a pdp-12", but what you were talking about would be much cooler (and exponentially harder).
We will definitely keep people posted about Julian's project; I'm trying to get him to sign up here.
We continue to test all testable flip chips. Hoping to finish today, and if luck smiles on us, repair two M216s that are failing.
@vrs42 @m_thompson and @DougIngraham -- we notice that there are many tests for M221 chips:
  • M221_IN.TST
  • M221.new
  • M221.NEW
  • M221.NEW.1
  • M221.NEW.2
  • M221_REG.TST
Is there a recommendation of which tests to do, or not to do (that is the question)? Thanks!
I'm imagining the next M221 test to be named something like M221.NEW.2.FINAL.FINAL.TST :ROFLMAO:
Funny, but I have seen documents labelled kind of like this. Not fun trying to figure out which is really the "final" one.
Yes, it would be best if the test suite could be amended to use functional names for these tests, if possible.
  • M221_IN.TST
  • M221.new
  • M221.NEW
  • M221.NEW.1
  • M221.NEW.2
  • M221_REG.TST
The M221 is by far the most complicated to test. There have been several running starts at it, but so far, no definitive approach has been developed which "tests everything". So I'd probably run them all, except one with the lowercase.
At one point, Kyle even wrote a file with about a zillion randomly generated vectors, figuring that was as likely to find a problem than a bunch of half-finished manually generated tests.
Vince
In general, if there's a "correct" test, it's called "Mxxx.TST", where Mxxx is the number of the flip chip module. Everything else is experimental or under development, though much of it is quite useful. Alas, Warren is deceased, so some of this is also historical.
If I had experience with something actually not working, I've probably renamed it so that the name has lowercase. That prevents it's selection in the tester software, as that mono-cases the input before attempting to look things up.
Vince
Thanks! That's great to know. I appreciate it.
Hey, that's a great idea!
Thanks. I think I was worried about something being misleading or dangerous, so avoiding the lowercase is helpful advice, and just knowing that the issue is not so much "bad tests" as that the M221s are just complicated to test thoroughly.
I also understand wanting it to reflect some of the history of the project and Warren's work. Makes sense to me!
As always, thank you for the context and helpful information.
I am, of course, also open to the possibility that someone will someday produce a proper set of vectors to fully test the M221 :-).
Vince
The video makes clear that I should have been more specific about which Kyle did the random vectors for the M221. That was Kyle Owen, not the Kyle in the video :).
Vince
Yes! I knew what you meant but clarity is great.
Hello! :)
Yes, random vectors were a fun thought for the M221, but what would be interesting is to leverage an expensive license of some ASIC automatic test vector generation tool. I probably could have had access years ago to such things at the university, but not anymore.
Sperry had a tool to do something like that. I worked in the design verification group on new hardware being developed. This piece of code generated code segments, then emulated that code to predict what the results would be and then ran the actual code. This did find some interesting flaws that may not have shown up any other way. I did not write that code, just saw it being used.
It was fun to notice this afternoon that our M169 card references LINC-8 by name:1000002301.jpg1000002300.jpg
