RSX11M+
- Joined
- Feb 14, 2011
- Messages
- 1,075
The Purpose of this Thread:
I'd like this to be a place for members to collect and share information allowing identification, duplication, and even replacement of missing DEC keys in a way a Locksmith could accomplish from standards. (without an original to copy)
I'm beginning with the more difficult ACE keys, but eventually we should be able to collect information on all DEC keys - CPUs, cabinets, etc...
Members willing to participate and possessing genuine DEC keys, please post them here, by key number, measured dimensions, and photographically if possible. Please mention the precise CPU it fits, if you know.
The Begining:
DEC PDP-11 KEY XX2247
So, with the work on my VAX 11/730, and a PDP-11/10, the subject of keys has come up. I misplaced the key to my 11/70 (like that? MY 11/70 - haven't seen the machine in 20 years) so the VAX 11/730 is the only key I have, but it's reportedly the same one as was the 11/780 and 11/70 keys. (maybe not... read on)
I see many posts on the internet referring to the Barrel key (aka - Tubular) number XX2247 as being for "most" PDP-11 CPUs and some VAX machines so I assume this is the same as the one I have.
Looking into it a little, this is what I've found.
Background Research:
This type of key was marketed as ACE by Chicago Lock. (Now CompX)
As was practice of the day, the number imprinted on each key is an INDEX number, which identifies it's geometry in a master list. This geometry is a CODE, consisting of numbers (1-8 ) for pin depths of pin numbers (1-7) and a rotational offset. Supposedly, "FULL SERVICE" locksmiths could make a new key directly from the CODE.
I've not found the master list on the internet. I don't know if "modern" locksmiths have it any longer. But since I have a key, and it's presumably one of these, I can MEASURE the pin depths and record them here.
This should enable anyone to have a duplicate made, and to check my key against theirs and identify it as a XX2247 (or not). My key DEFINITELY fits my 11/730, and turns the CPU lock. For the record, there is a stamped number on this key (MRP6231) - however I think it's a duplicated key and not an original number.
Barrel Keys:
Now, for my key: (in inches)
This would make the ACE depth "code" (pin#:depthcode) for my key 7654321:7557537 (adjusted) with pins "Symmetrical" (aka "Centered") about the tang.
In the FORT system, that would be: 1234567:6446426 as the depths and pin order are different in that standard.
Open Requests:
Thank You.
Note: If there's enough interest in this topic, I plan to ask the admins to make this forum a "Sticky" so the head post(s) can be re-edited and maintained with the currently established "up to date" key information.
UPDATE:
Confirmed ACE Keys and Uses:
The Begining:
Barrel Keys:
- PIN Identification: Holding the key looking into the open barrel end, one sees the cuts. These can be symmetrical around the "Tang" or offset "left" or "right". Mine is "Centered".
- Counting from the Tang - clockwise, the pin locations are numbered 7-1 in decreasing order. (ACE keys are numbered this way, FORT keys are opposite - increasing order 1-7)
- PIN Depths: 8 Depths are in 0.016" increments, beginning at 1 = 0.016" and ending with 8 = 0.128"
1 = 0.016
2 = 0.032
3 = 0.048
4 = 0.064
5 = 0.080
6 = 0.096
7 = 0.112
8 = 0.128
2 = 0.032
3 = 0.048
4 = 0.064
5 = 0.080
6 = 0.096
7 = 0.112
8 = 0.128
7=0.110
6=0.076
5=0.080
4=0.108
3=0.076
2=0.041
1=0.108
6=0.076
5=0.080
4=0.108
3=0.076
2=0.041
1=0.108
Open Requests:
- Please post any use of an XX2247 key not listed below
- Anyone who has an original DEC key, especially other than XX2247 - please post
- Also, if anyone uses this "code" information to have an "original" key made, please report your success or failure here.
Thank You.
UPDATE:
DEC# ACE CODE CPU
XX2247 7654321:5173757 PDP-8 (Classic)
XX2247 7654321:5173757 PDP-8/e
XX2247 7654321:5173757 PDP-8/I
XX2247 7654321:5173757 PDP-8/L
XX2247 7654321:5173757 PDP-8/m
XX2247 7654321:5173757 PDP-11/20
XX2247 7654321:5173757 PDP-11/30
Plastic Un-Cut PDP-11/44 (any ACE key works)
XX2247 7654321:5173757 PDP-11/45
? 7654321:7557537 PDP-11/730 (VAX)
