techtinkering.com has some good comparative reviews and advice on various classes of CP/M utilities.
Very informative. Choose your own favorites.
E.g.:
There are lots of great alternatives to the standard CP/M DIR command, which add extra functionality and combine features that normally have to be accessed throu
techtinkering.com
CP/M is by default a text-only affair. However, many of the machines that can run CP/M have hardware that would allow them to display graphics. As BBSing start
techtinkering.com
CP/M has a number of interactive file managers that can be used to make it easier to handle common file operations rather than using the command line driven comm
techtinkering.com
CP/M has the ability to handle lots of different compression and archive formats which was important due to the limited capacity of floppy disks and the cost of
techtinkering.com
The .LBR (Library) file format was the most common form of multi-file archive on personal computers at one time. It was created by Gary P. Novosielski in 1982 f
techtinkering.com
Lots of utilities make use of .LBR (Library) files to provide extra facilities such as the ability to run commands from archives or mount them as if they were dr
techtinkering.com
To do any serious programming under CP/M, the first thing you need is a good programmers editor. There aren't many in the archives, but I have tried most of the
techtinkering.com
(not affiliated with the techtinkering site in any way)
-- Tom S
