What are your favorite CP/M tools or utilities?
alank2
USA
I've found that UNZIP.COM works fine as long as I use PKZIP 1.1 to compress files.
I'm a fan of Zap or SuperZap.
I've just started using COPY that comes with ROMWBW and it is handy.
Survey is always handy.
du-v89.lbr
nswp207.lbr
nulu152a.lbr
unarc16.lbr
uncr28.lbr
~/DOS_Utils/Convert/convert.exe, convert.usr, & convert.doc
Larry
The one I still use all the time is SID (under emulation in a command window) whenever I want to do hexadecimal arithmetic. But under CP/M itself, my faves were:
ZDE for text editing
DU89/DU90: sector editor
Z8E: debugger
Dazzlestar: interactive disassembler
Other than my HP-16C for arithmetic, I use (gasp) google. Just key in, say,
0x23 * 1234
And it replies
0xA8B6
(note the mixed radius in the equation)
techtinkering.com has some good comparative reviews and advice on various classes of CP/M utilities.
Very informative. Choose your own favorites.
E.g.:
(not affiliated with the techtinkering site in any way)
-- Tom S
QL is probably my favourite utility. It's a text viewer that displays a directory of files and then you can easily look at each, even if they are squeezed or crunched and held in a .LBR file. It also contains a hex viewer. For a 10k utility it really is very good. Like Chuck, I'm also a big fan of ED.
I am affiliated with TechTinkering in every way ;)
The entire Z-System environment.
To wit you now come down to I think a core question.
When does CP/M stop being CP/M.
Is CP/M just the BIOS and BDOS, or is it more of the stack (CCP, PIP, the other CP/M utilities).
Wordstar... Might seem a strange choice, but I used it as the editor when coding for a few years, and really began to appreciate it.
Wordstar is the reason my High School computing teacher told me I would never have a career in technology.
Wordstar is the reason the University I attended kicked me out of my course.
Wordstar is the reason I lost my student support and had to get a job.
And the first job I got was in a R&D lab writing z80 asm files in..... Wordstar.
After that, I started to like Wordstar.
One could quibble all day about this question, but in my view it comes down to: "Does the environment support most/all of the applications developed for CP/M".
E.g.:
-- Tom S
Nice articles! Unfortunate, though, that there are no links in the article on where to download those utilities.
As mloewen says they are available in the *Humongous* CP/M Software Archive, specifically on the Walnut Creek CD - although there are lots of different versions of these tools available on it. If you look again at the article you will see a link near the start of each tool section which links to the best version of each that I could find.
