Chuck(G)
Gone, but never forgotten.
What kind of a question is that? Bloat is a unidirectional monster. It has a diode on it so it can't go backwards. I thought you knew that.
Ah, "Bloat's arrow"
| VCF Latam | Apr 24 - 26, 2026, | Bahía Blanca, Argentina |
| VCF Pac. NW | May 02 - 03, 2026, | Tukwila, WA |
| VCF Southwest | May 29 - 31, 2026, | Westin Dallas Fort Worth Airport |
| VCF SoCal | See you in 2027, | Southern CA |
| VCF East | Apr TBD, 2027, | InfoAge, Wall, NJ |
Is Windows 7's support that much worse than 2000/XP? For a lot of the things I need to do, I find that only Windows 95/98 can really handle it.
That's a "feature" I've been using on my RH7.3 box for over a decade. Resistance is futile you will be assimilated!!
I don't think its much bigger than windows/7. Not sure I like the multiple desktop support which allows you to have several "desktops" and rotate between them, and the metro apps ....
.. I kind of miss the "move the cursor to the top right to move round"..
Originally Posted by coleoptere2007
They will made the floppy drivers in next release, as i asked the question to M$ support ==> Answer : we are doing all the effort to make it available in next release as someone forgot to compile it on W10TP
the sys file hasn't been compiled but the inf files are there, look at
C:\Windows\System32\DriverStore\FileRepository>dir *fdc*
Directory of C:\Windows\System32\DriverStore\FileRepository
13.09.2014 09:22 <DIR> c_fdc.inf_amd64_c7989d4ec4b68a79
C:\Windows\System32\DriverStore\FileRepository>dir *floppy*
04.10.2014 02:38 <DIR> c_floppydisk.inf_amd64_d5508983e82424d5
You know it's just a matter of time. First it was the 8 inch, then the 5 1/4 now it's the 3 1/2 and the optical drives. Will the magnetic hard drive be far behind? PATA drives are disappearing.
Latest build restored floppy support.
Both legacy and USB?
Well I downloaded and installed the Win 10 Technical preview X86 version and found out to my dismay that Floppy drive support has been dropped! Not only the internal drive connected to the mainboard but also USB floppy support. Could be a deal killer for anyone who may be thinking of upgrading to it. But then it could be added before the final release. Let's hope so.
