I'm not 100% sure myself the final circuit configuration that @Desperado ended up with, with all the changes that were required to make it work, that is why I suggested that he looked at it and wrote down and posted what circuit he currently has, so there are no mistakes.sorry hugo, I didn't explain myself well. I need to know the connections for 74ls123 and 74ls221.
the connection between IC2A, IC2B, IC3A, because I noticed a different connection from the initial one
ic2 pin 12 = 20 us???So, what are the pulse lengths then?
Have a go yourself at measuring these - otherwise you will not learn how to do it...
Post your 'working out' as well (so I can see where you go wrong if we don't agree regarding the measurements).
White flag for these measurementsWhy are you desperate?
How did you get your 20 us? Please show your working out.
I think one main issue was that the output of IC2A needed to be swapped to the /Q (pin4) rather than Q output (not shown on the previously simplified diagram) , or we could not get any time delay out of it because the Q output rises almost synchronously with the trigger.sorry hugo, I didn't explain myself well. I need to know the connections for 74ls123 and 74ls221.
Five !So how many fractions have you got in a full division on the screen?
