Commodore PET 2001-8 text wobbling on screen
For the flux band to work perfectly it has to be wrapped around the transformer completely and soldered together across its full width. Any currents generated due to the alternating flux are applied to a shorted ring/band of low resistance copper and they generate an opposing alternating magnetic field to cancel the applied one. The edges of that half shield might get some connection via the lamination edges, but that would be very unreliable.
Well, following you advise I used a 0,8mm cooper band but the problem now is that I cannot solder the end of the band. As you can see in the picture I filed the cooper with the Dremel and pre-soldered at both sides but my 40W JBC solder iron is not enough to melt such a quantity of tin even using flux.
Any idea ? Maybe to glue the band in any way instead of solder ? If so, what glue can I use?
You can't use glue, it is not conductive!
You need a larger wattage soldering iron for that job.
Do you know someone with a larger soldering iron that you could borrow or they could solder for you?
For that thickness copper it requires a very large soldering iron, in the order of 200W. I use a 200W Weller.
Just some tips:
Don't use any liquid or additional fluxes, they are very corrosive and could get into the transformer windings and cause trouble later.
To help protect the surface of the transformer I would normally put a layer of Scotch 27 fiberglass tape over the surface under the copper band.
Copper (when up to temperature) is extremely easy to solder to, especially if you have proper 60/40 Multicore solder. No additional fluxes are required, the special flux is non corrosive even if left behind.
I can already see corrosion from the flux you added.
I never use liquid fluxes or added fluxes because all that is required is in the Multicore solder. The flux in it has been especially developed for electronic work and is completely inactive at temperatures below the soldering temperature.It also works well on copper, brass, tin plated steel, steel, etc. It does not go on to attack copper or other metals if left behind. Liquid fluxes can be very destructive in the long run to electronic parts and pcb's. Residual fluxes are the cause of items like meter movements, electronic delay lines, heads in disk drives small transformers with fine wire etc going open circuit due to corrosion near the solder terminations.
Flux pastes(creams) are needed for surface mount pcb work and all traces of that are better washed off.
One reason people reach for added fluxes is that they have never experienced a proper solder product with a multicore flux and struggle with surfaces that are oxidized and in desperation add flux. It is no drama if its a car radiator you are soldering up, you can add as much flux as you want, but with general electronics gear & components its a problem.
There are plenty of poor quality solders on the market with inferior flux sadly.
The point is though, any Blacksmith named Mr. Bloodaxe or Mr. Irongron from the year 1640 could make a 60/40 mixture of fairly pure Tin & Lead for you, that is not the problem.
All of the modern technology is in the Flux cores.
It took about 30 or 40 years of development for Multicore in the UK to create the flux in their 5 core solders, the recipe was basically complete by the early 1970's and like the formulations for capacitor electrolytes which are very complex, others copied it, with varying degrees of success & failure. This is also the type of solder used in the Avionics industry (luckily they have not been sucked into Lead free solder or I would never fly on a plane again). Once you have used it you will never reach for additional fluxes or any other solder product.
Multicore in the UK also pioneered the fluxes (solder creams) used to make early surface mount designs such as LED watches. See the attached advert from Wireless World 1978. Multicore were making 3 core solders in the early 1940's, even then they were thought to be superior.The company Multicore I think went on to become part of Henkel International.
Also, once your copper band is properly soldered, and you have cleaned it, you can apply a coat of varnish to it with a brush. I use marine spar varnish because it is resistant to cracking, it is very similar to transformer varnish. This preserves the appearance of the copper band and prevents corrosion of the surface, which can get unsightly with bare copper.
Well, finally I managed to get a 150W iron solder and in this way was easy to solder the cooper band. Inexplicably, there's no improvement on the screen, it vibrates exactly the same as before :eek:.After so much work, I decided to leave it as it is, with the PCB board repaired and updated to BASIC 4.0.
By the way, when I connected the SD2PET, it failed, perhaps because the edge connectors had been left without something connected for so long. After cleaning them with isopropyl alcohol, it worked correctly again. These connectors are a mystery to me...
When this has happened to me it was because I was using the wrong EDIT ROM. There are 50hz and 60hz versions.
If you're able to burn a replacement it's at least a non-intrusive thing to try.
Colin.
Colin.
Thank you for your advise but If I'm not wrong, for CBM3032 non-CRTC 40 columns BASIC 4.0 there's only one version and is the same for 50Hz and 60Hz (edit-4-n.901447-29.bin).
Just looking at the photo you posted, the base of the VDU cabinet seen from beneath looks thick, as though you probably have the plastic cased, rather than the metal cased VDU ? And the PET top is also a plastic version.
If that is the case, the VDU is much more vulnerable to magnetic field disturbances from the transformer, it requires the steel metal shield plate fitted to the casing below the VDU like the one seen on post #43.
In this case, which is more effective? Aluminum or steel? (1 mm thick both).
If that shield is acting entirely on the principle of Lenz's law, shielding on the basis of alternating magnetic fields, the order of preference would be Copper, Aluminium than steel because of the electrical conductivity.
However, I think that plate, if it was steel, might be a little more effective because of steel's magnetic shielding effects, unlike the flux band its not a shorted enclosure. If that were the case then Mu metal would be better than steel. And the metal (steel) cased VDU's and steel topped PETs appear less problematic. So I would try a steel plate first. Also, from the pictures I have seen, most of the original plates looked as though they were probably zinc plated steel.
Well, finally I installed a 05mm. steel shield as you can see in the picture and the wobbling was notory improved. Is not perfect as when the lid is opened and the screen is far away from the transformer, but I'm happy with the result. Now it's time to enjoy the PET ;) (Maybe I'll connect a small sound amplifier to tje user's port but this will bethe end.
Well done!
That is one of the drawbacks of the plastic case vs the metal case...
Just make sure the metal sheet cannot short out the terminals on the transformer...
