NeXT
The economizing is what kills the benefits of LED for me.
The whole schtick is that an LED will last tens of thousands of hours, but the supporting hardware is so poorly designed that on average the life of the entire light can be measured in 2-3 years at best, 8 hours a day. The result is large amounts of E-waste consisting mostly of components that cannot be serviced due to how cheaply assembled the unit is, in part because it encourages one to just replace it when it fails, rather than longevity over sales.
It's the example with the streetlights suffering from LED pigmentation failure and turning purple/violet. You can't replace just the LED assembly. You have to replace the ENTIRE lamp.
CFL got the same treatment I guess. Those Circline and (T4?) style desk lamp bulbs you used to get the bulbs and the ballasted lamp base separate. Nice magnetic ballasts with the starter hiding in the base of the bulb or the ballast. By the end the spiral lights were fully integrated units, often disposed of because the electronic ballasts would overheat and fail.
