I love it when one can see in an old computer exactly what the designers were thinking to make the machine the way it was. I have just received from my old Honeywell engineer friend a precise template for the positions of the holes for the buttons on the H200 control panel traced directly from an original fascia taken from such a panel. This will enable me to create the metal mounting panel for the switches in my replica with those switches in precisely the correct positions. That simple drawing told me something else though without a single word being necessary on it. In fact the very absence of words was the key to this fascinating snippet of information.
If you can't remember the exact layout of the panel look at my CAD picture of one on the home page of my website mentioned below in my signature.
The layout of the upper buttons used to set and view control register, address and contents values was self-evident and the buttons on the right used to display and update these also followed a similar spacing pattern but the master controls for the machine along the bottom were spaced in a peculiar way that didn't correspond to any other buttons and I wondered why until I realised the simple explanation, that the H200 was designed to be made as cheaply as possible.
Here is a picture of buttons taken from some other machine which used exactly the same type of switches as the H200.
Here the switches were obviously mounted horizontally so that there was room on the buttons for the text, but these buttons were each made from two special plastic mouldings, one for the button itself and another for the transparent cover over the slip of plastic with the text printed on it. The mouldings even had a stop incorporated into them so that the buttons couldn't accidentally be inserted upside down. These looked like expensive items to make, even in quantity, so Honeywell came up with a different most likely cheaper solution.
Their buttons were made very simply from a continuous plastic extrusion chopped into appropriate lengths, no doubt far cheaper than the complicated moulded buttons above. To avoid printing text on the buttons themselves where it would get worn off they printed it on the fascia of the control panel itself, which only needed one screen printing operation to make the whole thing anyway. In the place of text on the buttons they just painted simple symbols as a clear indication of which was which, so the text on the fascia was just there as an extra reminder of each button's function.
Now comes the artistic part. As there was no text on the buttons they could just as easily be mounted vertically as horizontally and by keeping the original spacing of the horizontal buttons the fascia would not have one long hole in it but several small ones, which no doubt made it more stable.
Now I knew exactly why the buttons were spaced the way that they were, because originally they were going to be placed horizontally hard up against each other as on other machines but someone thought of this way to cut costs and in the process make the panel look more visually appealing. To discover this all I had to do was put a switch on the template and turn it round and as soon as I did that it all became clear.
Well, that's another little mystery solved then, but maybe one that many people wouldn't even have given a thought. It all depends exactly why we each do what we do with these old machines.
